I have here a BG95 which is operated at a Hi-Speed USB 2.0 hub LAN9513 from Microchip. We have been looking for the source of the error for several days now:
Extract from the error log dmesg:
[ 1163.989811] usb 1-3.2: new high-speed USB device number 98 using tegra-xusb
[ 1164.015588] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0700
[ 1164.015594] usb 1-3.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 1164.015598] usb 1-3.2: Product: Quectel LPWA Module
[ 1164.015601] usb 1-3.2: Manufacturer: Quectel, Incorporated
[ 1164.015605] usb 1-3.2: SerialNumber: 55d06ec3
[ 1164.019060] option 1-3.2:1.0: GSM modem (1-port) converter detected
[ 1164.019346] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1164.019523] option 1-3.2:1.1: GSM modem (1-port) converter detected
[ 1164.019694] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1164.019879] option 1-3.2:1.2: GSM modem (1-port) converter detected
[ 1164.020044] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1164.020271] option 1-3.2:1.3: GSM modem (1-port) converter detected
[ 1164.020453] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1170.422738] usb 1-3.2: USB disconnect, device number 98
[ 1170.424464] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1170.424507] option 1-3.2:1.0: device disconnected
[ 1170.426755] option1 ttyUSB3: usb_wwan_open: submit int urb failed: -19
[ 1170.426770] option1 ttyUSB3: usb_wwan_open: submit read urb 0 failed: -19
[ 1170.426778] option1 ttyUSB3: usb_wwan_open: submit read urb 1 failed: -19
[ 1170.426785] option1 ttyUSB3: usb_wwan_open: submit read urb 2 failed: -19
[ 1170.426793] option1 ttyUSB3: usb_wwan_open: submit read urb 3 failed: -19
[ 1170.429270] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1170.429295] option 1-3.2:1.1: device disconnected
[ 1170.429651] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1170.429677] option 1-3.2:1.2: device disconnected
[ 1170.430006] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1170.430032] option 1-3.2:1.3: device disconnected
[ 1173.977413] usb 1-3.2: new high-speed USB device number 99 using tegra-xusb
[ 1174.003195] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0700
[ 1174.003201] usb 1-3.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 1174.003206] usb 1-3.2: Product: Quectel LPWA Module
[ 1174.003209] usb 1-3.2: Manufacturer: Quectel, Incorporated
[ 1174.003213] usb 1-3.2: SerialNumber: 55d06ec3
[ 1174.006730] option 1-3.2:1.0: GSM modem (1-port) converter detected
[ 1174.007019] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1174.007256] option 1-3.2:1.1: GSM modem (1-port) converter detected
[ 1174.007519] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1174.007739] option 1-3.2:1.2: GSM modem (1-port) converter detected
[ 1174.007995] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1174.008261] option 1-3.2:1.3: GSM modem (1-port) converter detected
[ 1174.008658] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1180.406725] usb 1-3.2: USB disconnect, device number 99
[ 1180.408577] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1180.408606] option 1-3.2:1.0: device disconnected
[ 1180.410396] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1180.410450] option 1-3.2:1.1: device disconnected
[ 1180.413220] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1180.413250] option 1-3.2:1.2: device disconnected
[ 1180.413827] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1180.413854] option 1-3.2:1.3: device disconnected
[ 1183.957029] usb 1-3.2: new high-speed USB device number 100 using tegra-xusb
[ 1183.982718] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0700
[ 1183.982725] usb 1-3.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 1183.982729] usb 1-3.2: Product: Quectel LPWA Module
[ 1183.982732] usb 1-3.2: Manufacturer: Quectel, Incorporated
[ 1183.982736] usb 1-3.2: SerialNumber: 55d06ec3
[ 1183.986932] option 1-3.2:1.0: GSM modem (1-port) converter detected
[ 1183.987196] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1183.987379] option 1-3.2:1.1: GSM modem (1-port) converter detected
[ 1183.987547] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1183.987739] option 1-3.2:1.2: GSM modem (1-port) converter detected
[ 1183.988096] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1183.988310] option 1-3.2:1.3: GSM modem (1-port) converter detected
[ 1183.988506] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1190.646688] usb 1-3.2: USB disconnect, device number 100
[ 1190.648858] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1190.648926] option 1-3.2:1.0: device disconnected
[ 1190.652061] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1190.652102] option 1-3.2:1.1: device disconnected
[ 1190.655517] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1190.655567] option 1-3.2:1.2: device disconnected
[ 1190.656001] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1190.656027] option 1-3.2:1.3: device disconnected
[ 1194.204709] usb 1-3.2: new high-speed USB device number 101 using tegra-xusb
[ 1194.230190] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0700
[ 1194.230196] usb 1-3.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 1194.230199] usb 1-3.2: Product: Quectel LPWA Module
[ 1194.230202] usb 1-3.2: Manufacturer: Quectel, Incorporated
[ 1194.230204] usb 1-3.2: SerialNumber: 55d06ec3
[ 1194.236370] option 1-3.2:1.0: GSM modem (1-port) converter detected
[ 1194.236910] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1194.237324] option 1-3.2:1.1: GSM modem (1-port) converter detected
[ 1194.237587] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1194.237954] option 1-3.2:1.2: GSM modem (1-port) converter detected
[ 1194.238528] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1194.239058] option 1-3.2:1.3: GSM modem (1-port) converter detected
[ 1194.239404] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1200.630659] usb 1-3.2: USB disconnect, device number 101
[ 1200.633026] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1200.633106] option 1-3.2:1.0: device disconnected
[ 1200.634598] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1200.634626] option 1-3.2:1.1: device disconnected
[ 1200.635500] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1200.635542] option 1-3.2:1.2: device disconnected
[ 1200.635896] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1200.635927] option 1-3.2:1.3: device disconnected
[ 1204.180172] usb 1-3.2: new high-speed USB device number 102 using tegra-xusb
[ 1204.206057] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0700
[ 1204.206063] usb 1-3.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 1204.206068] usb 1-3.2: Product: Quectel LPWA Module
[ 1204.206071] usb 1-3.2: Manufacturer: Quectel, Incorporated
[ 1204.206074] usb 1-3.2: SerialNumber: 55d06ec3
[ 1204.209543] option 1-3.2:1.0: GSM modem (1-port) converter detected
[ 1204.209841] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1204.210023] option 1-3.2:1.1: GSM modem (1-port) converter detected
[ 1204.210269] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1204.210465] option 1-3.2:1.2: GSM modem (1-port) converter detected
[ 1204.210659] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1204.210892] option 1-3.2:1.3: GSM modem (1-port) converter detected
[ 1204.211070] usb 1-3.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1210.614658] usb 1-3.2: USB disconnect, device number 102
[ 1210.616790] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1210.616824] option 1-3.2:1.0: device disconnected
[ 1210.619043] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1210.619103] option 1-3.2:1.1: device disconnected
[ 1210.622602] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1210.622650] option 1-3.2:1.2: device disconnected
[ 1210.623042] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1210.623073] option 1-3.2:1.3: device disconnected
The power supply was our first idea but we have now recorded several times with special measuring devices. It looks very good.
So far I have only installed the driver as shown here. Otherwise we have not made any further in Linux settings
What could be the problem?
Thanks for the help ![]()
