Hi All,
I used the UMTS & LTE-EVB-KIT development kit with the BG96 module.
Now I have replaced the BG96 development module with a new BG95M3-LATEA module.
The module work, it turns on and responds correctly if queried through the “main” RS232 serial port.
The issue it’s on the USB connection. The PC with windows 10 doesn’t even notice that the BG95M3 module is connected and doesn’t detect any USB connection.
I have done various tests. I’ve removed and reinstalling different drivers, but checking the USB devices list, there insn’t any new device.
I checked on this forum BG95-m3-boots-but-does-not-communicate-over-usb and managed to update the firmware (asked the local distributor) through “emergency boot” with shorting the jumper on J201 (VDD_EXT to BOOT_PIN).
After restarting the module, the firmware it’s was upgraded, (BG95M3LAR02A03_01.006.01.006) but the USB still does not work.
What’s wrong?
Thanks.
