I am sending udp packet to a server using “UDP” mode. It works but when I receive the packet I can see on the server side that the “origin” port of the packet is not set using “local_port” parameter I set. As a result, network firewalls does not let the answer goes back. (I am using an old version of BG95 firmware).
I am using
AT+QIOPEN=0,0,“UDP”,mydomainname,10101,10101,0
It works but,
received udp packet has (source_ip: device_ip, source_port: RANDOM, dest_ip: domain_ip, dest_port: 10101)
What is the best way to get udp answers goes back to the BG95 ? do I need to have source_port = dest_port so both devices uses the same port and then telecom network let packets goes around ?
Hello. My server is based on xinetd that does not provide REMOTE_PORT to underlying script. I try to find some turnaround before having to rewrite the server to have proper socket handling udp. I could send properly some answer payload using “socat” but I miss the actual port used by the device. Since source port “REMOTE_PORT” is random i need to find some tricks. That is why I am trying to have the device use some fixed source port.
