Hi All
We have been using the BG96 till now, but have started working with BG95-M3.
I would like to know what are other users experiences with the new device and if you had a smooth migration?
I am having some issues when selecting a networks manually using COPS=?, where i get errors message unless i wait 5 seconds before the results are produces and a operator is selected.
Another issue i am experiencing is with GPS, when selected then MQTT is no longer as stable.
Regards
DJ
https://forums.quectel.com/t/bg95-unstable-tcp-client-connections/4070/10
from quectel R&D
"When we use just UART interface it takes long time to create socket connection and also getting ACK for TCP data. We will check and analyze this issue internally and inform you asap. "
Since the BG95 share RF channel , we can not use the LTE and GNSS in the meanwhile ,
Maybe it is the rootcause ,
pls kindlyload Quectel_BG95&BG77&BG600L_Series_GNSS_Application_Note_V1.3.pdf
from the below link
https://cnquectel-my.sharepoint.com/:f:/g/personal/ae-fae_quectel_com/ErC7rOSC-zVAg4Y-foSwd_YBP9H4r7xbfoFdFFl-snYWVQ?e=JBlX4h
