Hi, What commands should I issue to the BG95-M3 if I need to Reset the module?
AT+CFUN=1,1 this will reboot the module.
I am looking for a procedure to totally reset a BG95 module.
In particular I would like to reset the memory containing stored data like the XTRA File. I have tried the AT&F Command but looks like the memory containing XTRA file is still there.
Have you found any command procedure to get a full reset? Any suggestion?
Thanks in advance
Giulio
