I did some tests with a BG95-M3 module on roaming networks for a tracker device.
Generally it works fine but when crossing countries there are problematic situation, so I would like to make it fault tolerant with minimum energy consumption in all problematic cases.
The examples in the manuals all are fragments for specific commands but I’m looking for a setup recommendation which does:
check if any scanned operator accepts the APN.
exclude operators which does not support PSM (I saw operators which accepts the APN but does not support PSM).
if no available operators support PSM nevertheless use a available operator (without PSM) and use a adequate power down sequence.
prevent excecive power-on if no operator is shown or the module hangs.
Do you have a connection setup flowchart for this “do it all” use case?
The problem appears when you travel across several countries: there are often operators which does/does not allow PSM and by doing a scan you dont’ find out which supports PSM - you have to connect and try and this is a) not the fastest way to find out and b) drains battery and c) costs a connect.
Quectel already published a flowchart for reliable connecting but unfortunately this is without PSM.
What I would prefer is a flowchart or pseudocode for this from Quectel.
