Bg95 M3 reboot when it try attach to the network
Hi! I designed a BG96 M3 Custom Board (following the instrucción from hardware design datasheet). When I send it an AT+COPS=0,2,“334020”,0 the BG96 reboot it self.
cops=0 is the automatic network selection mode. If you want to manually configure the network, use cops=1
OK. I changed the command, but the module continues with the same
