Dear Quectel Support Team,
I am currently developing an OTA firmware update solution using a BG95-M3 module and I would appreciate your guidance regarding an issue that occasionally occurs during HTTP file downloads.
Module Information
Module Model: BG95-M3
Firmware Version: BG95M3LAR02A03_A0.206.A0.206
IMEI: 865918071798430
HTTP Configuration
After powering up the module, I configure the HTTP service using the following commands:
AT+QHTTPCFG="contextid",1
AT+QHTTPCFG="requestheader",0
AT+QHTTPCFG="responseheader",0
AT+QHTTPCFG="contenttype",1
AT+QHTTPCFG="sslctxid",1
OTA Download Procedure
- Configure the URL:
AT+QHTTPURL=<URL_SIZE>,80
- Send an HTTP POST request:
AT+QHTTPPOST=<data_size>,80,80
Parse the server response and obtain the OTA download URL.
Execute:
AT+QHTTPREAD=80
Parse the response data and determine whether a firmware download is available.
Configure the download URL:
AT+QHTTPURL=<DOWNLOAD_LINK_SIZE>,80
Send the download URL content.
Start the download using:
AT+QHTTPREADFILE="my_download_file",500
- Monitor the download progress by querying the file size every 3 seconds:
AT+QFLST="my_download_file"
- The download process is considered complete when the file size matches the size reported by the server.
Observed Issue
This procedure works reliably most of the time.
However, in some situations, during the execution of AT+QHTTPREADFILE, the download appears to stop unexpectedly. When this happens:
The file size reported by
AT+QFLSTstops increasing. -
The file remains incomplete.
The module does not report any explicit error.
The download never resumes.
The file size remains unchanged indefinitely.
The issue appears to occur randomly and is difficult to reproduce consistently.
Questions
Are there any recommended HTTP, TCP/IP, SSL, PDP, or file system configurations that could improve the robustness of large file downloads using
AT+QHTTPREADFILE? -
Is there any internal timeout parameter associated with
QHTTPREADFILEthat should be adjusted for large OTA files? -
Are there known limitations or known issues with firmware version BG95M3LAR02A03_A0.206.A0.206 related to HTTP file downloads?
In scenarios involving temporary network degradation, packet loss, server delays, or interrupted connections, what recovery mechanism does Quectel recommend? For example:
Restarting the HTTP session
Re-establishing the PDP context
Reissuing the download request
Using HTTP Range requests
Other recommended approaches
Any recommendations regarding best practices for implementing a reliable OTA download mechanism on the BG95 platform would be greatly appreciated.
Thank you for your support.
Best regards,
Daniel Pazzini
