BG95-M3 not enterning PSM
We have problem with module BG95-M3(app version: 01.014.01.014), which can’t to enter PSM.
I tried:
AT+QPSMS=1,,,"10000010","00001000"
AT+QPSMS?
+QPSMS: 1,,,"60","16"
AT+CEREG?
+CEREG: 4,1,"E8D0","2FDA910",8,,,"00001000","01111110"
AT+QCFG="psm/enter",1
AT+QNWINFO
+QNWINFO: "eMTC","26003","LTE BAND 20",6200
The power consumption is always above ~25 mA, which has regular peaks probably during paging window. I have no idea what is the reason of not entering PSM.
I uploaded some logs in attachment.
some_logs.zip (1.6 MB)
please execute “AT+QSCLK=1” and try it again
I tried "AT+QSCLK=1”, but it didn’t solve the problem. I have disconnected USB, all commands are sending via UART. MAIN_DTR is connected to nothing on my PCB board and I’m not using it.
Are you sure your APN of SIM card supports PSM?
