I’m using BG95-M3 miniPCIe and EVB kit. It does not give me the option to use the AT Port after installing the driver “Quectel_LTE&5G_Windows_USB_Driver_V2.2.2”.
Is there any other Driver that I’m missing. The ports only show Quectel USB DM Port and Quectel USB NMEA Port. How about the Quectel USB AT Port?
Thanks for your help, Do you know why is not showing in the device manager section? Maybe is just me but I’m using a windows 10 pc or that is the way it is?
How come you are describing two different interfaces after saying that the BG95 only has 4 interfaces which you described them from 0-3(total of 4 interfaces). interfaces 3 is used for modem and AT port. My question was what interface is used for the PPP protocol? is it the same interface as the modem and AT port?
