I’m aware that examples must be changed for them to work, my problem is that those commands are not available. This is response to a main LwM2M command:
AT+QLWCFG=?
+QLWCFG: "select",(0-5)
Where documentation expects something like this:
Response
+QLWCFG: "autostart",(list of supported <startup_mode>s)
+QLWCFG: "pdpcid",(range of supported <client_index>s),(range of supported <PDP_cid>s),(list of supported <APN_class>s)
+QLWCFG: "security",(range of supported <client_index>s),(range of supported <shortID>s),<server_addr>, list of supported <bootstrap>s),(list of supported
<security_mode>s),<PSK_ID>,<PSK_key>
+QLWCFG: "server",(range of supported <client_index>s),(range of supported <life_time>s),(range of supported <period_min>s),(range of supported <period_max>s),(range of supported <disable_time>s),(list of supported <storing>s),<binding>
+QLWCFG: "epns",(list of supported<type>s),<bs_epname>,<reg_epname>
+QLWCFG: "transcfg",(range of supported <retry_timeout>s),(range of supported <retry_exponent>s),(range of supported <max_timeout>s)
+QLWCFG: "version",(list of supported <client_version>s)
+QLWCFG: "select",(range of supported <server_type>s),(list of supported <is_commercial>s)
+QLWCFG: "host",(list of supported <host_index>s),(range of supported <hostID>s),<host_value>
+QLWCFG: "device",<manufacturer>,<model_no>,<hw_version>,<sw_version>,<fw_version>,device_type>
+QLWCFG: "session",(range of supported<DTLS_timeout>s),(range of supported <resume_time>s)
+QLWCFG: "mbsps",<service_code>,<IMEI>,<MSISDN>,<ICCID>,<model>,<MAC>
