BG95-M3 keeps dropping connection and failing to reconnect
I have BG95-M3 with firmware version: BG95M3LAR02A03_01.011.01.011. I am having trouble to get connected, or reconnected when connection is dropped. Once the USB serial port rebooted, it can get connected immediately (but not for long). Is it firmware issue? Is there an update to stop the connection dropping issue?
Here is the log:
[01:15:19.512] ONE-TIME SETUP
[01:15:19.512] >> ATI
[01:15:19.812] << ATI
[01:15:19.813] << Quectel
[01:15:19.813] << BG95-M3
[01:15:19.813] << Revision: BG95M3LAR02A03
[01:15:19.813] << OK
[01:15:19.813] >> AT+CPIN?
[01:15:20.114] << AT+CPIN?
[01:15:20.114] << +CPIN: READY
[01:15:20.115] << OK
[01:15:20.115] >> AT+QGPS=1
[01:15:20.416] << AT+QGPS=1
[01:15:20.416] << OK
[01:15:20.416] >> AT+COPS=0
[01:15:20.717] << AT+COPS=0
[01:15:20.717] << OK
[01:15:20.717] >> AT+QICSGP=1,3,“fast.t-mobile.com”,“”,“”
[01:15:21.018] << AT+QICSGP=1,3,“fast.t-mobile.com”,“”,“”
[01:15:21.018] << OK
[01:15:21.018] >> AT+QIDEACT=1
[01:15:21.319] << AT+QIDEACT=1
[01:15:21.319] << OK
[01:15:21.319] >> AT+QIACT=1
[01:15:21.620] << AT+QIACT=1
[01:15:21.620] << OK
[01:15:21.621] CFUN reset: radio off …
[01:15:21.621] >> AT+CFUN=4
[01:15:23.621] << AT+CFUN=4
[01:15:23.622] << OK
[01:15:23.622] << +QIURC: “pdpdeact”,1
[01:15:23.622] CFUN reset: radio on …
[01:15:23.622] >> AT+CFUN=1
[01:15:26.623] << AT+CFUN=1
[01:15:26.623] << OK
[01:15:26.623] CFUN reset: waiting for PDP auto-reactivation …
[01:15:26.623] Pinging 8.8.8.8 (attempt 1/5) …
[01:15:26.623] >> AT+QPING=1,“8.8.8.8”,5,1
[01:15:26.645] << AT+QPING=1,“8.8.8.8”,5,1
[01:15:26.645] << OK
[01:15:26.645] << +QPING: 561
[01:15:36.626] Ping attempt 1 failed
[01:15:38.626] Pinging 8.8.8.8 (attempt 2/5) …
[01:15:38.627] >> AT+QPING=1,“8.8.8.8”,5,1
[01:15:38.648] << AT+QPING=1,“8.8.8.8”,5,1
[01:15:38.648] << OK
[01:15:38.649] << +QPING: 561
[01:15:48.630] Ping attempt 2 failed
[01:15:50.630] Pinging 8.8.8.8 (attempt 3/5) …
[01:15:50.631] >> AT+QPING=1,“8.8.8.8”,5,1
[01:15:50.652] << AT+QPING=1,“8.8.8.8”,5,1
[01:15:50.652] << OK
[01:15:50.653] << +QPING: 561
[01:16:00.632] Ping attempt 3 failed
[01:16:02.633] Pinging 8.8.8.8 (attempt 4/5) …
[01:16:02.633] >> AT+QPING=1,“8.8.8.8”,5,1
[01:16:02.654] << AT+QPING=1,“8.8.8.8”,5,1
[01:16:02.655] << OK
[01:16:02.655] << +QPING: 561
[01:16:12.635] Ping attempt 4 failed
[01:16:14.636] Pinging 8.8.8.8 (attempt 5/5) …
[01:16:14.636] >> AT+QPING=1,“8.8.8.8”,5,1
[01:16:14.657] << AT+QPING=1,“8.8.8.8”,5,1
[01:16:14.657] << OK
[01:16:14.658] << +QPING: 561
After you re-enable the RF in the modem (AT+CFUN=1) it can take som minutes to re-establish the connection. Try a delay.
I can make it work with AT+CFUN=1,1. That’s the only way I can get it connected every time the module wakes up.
