BG95-M3 GNSS cannot download XTRA
Hello, I cannot download the XTRA file for GNSS. See below the firmware and command set used. Does anyone have this problem too and know the solution?
Hardware: BG95-M3
Firmware: BG95M3LAR02A04_01.003.01.003
Network: LTE (Odido / T-mobile)
Command set and results:
AT+CFUN=1
AT+COPS?
+COPS: 1,0,“Odido”,8
AT+CEREG?
+CEREG: 0,5
AT+QIDNSCFG=1,“8.8.8.8”,“8.8.4.4”
AT+QPING=1,“http://iot1.xtracloud.net”,1,5
+QPING: 565
AT+QPING=1,“iot1.xtracloud.net”,1,5
+QPING: 0,“18.239.50.98”,32,87,255
+QPING: 0,“18.239.50.98”,32,78,255
+QPING: 0,“18.239.50.98”,32,79,255
+QPING: 0,5,5,0,78,87,81
AT+QGPSCFG=“xtra_apn”,0,“http://iot1.xtracloud.net/xtra3ge_24h.bin
AT+QGPSCFG=“gnssconfig”,3
AT+QGPSCFG=“galileonmeatype”,3
AT+QGPSCFG=“priority”,0
AT+QGPS=1,1,0,1,0
AT+QGPSLOC=5,2
+QGPSLOC: , , , , , , , , , ,
+…<+10 minutes: very long time no location data>…
+QGPSLOC: 120232.000, …… ,06
AT+QGPSCFG=“xtra_download”,1
+QGPSURC: “XTRA_DL”,-1
Is there maybe someone from Quectel that could help me?
Hi @GrandPep
Sorry for the late response !
Have you enabled XTRA freature by AT+QGPSXTRA=1 (reboot to take effect). ?
Here is an example for reference:
Pardon me, yes this was done before the commands above, so after AT+QGPSXTRA=1 and after the reboot. I retried this a few times too, setting AT+QGPSXTRA to 0 and 1 again with rebooting.
I’ve also tried all the following xtra_apn’s which all did not work, and also all possible files available:
iot1.xtracloud.net
http://18.239.50.28/xtra3ge_24h.bin
18.239.50.28
We need modem log to check why download failed.
Is there a manual on how to do so, preferable for Windows?
Hi @GrandPep
Firstly, you need download this log tool:QWinLog_V1.8_EN | Quectel
Here is steps:
Settings → system setting , and do following:
After all settings are ok, then:
  1. START button to start collect log.
  2. AT+QCFG=“dbgctl”,0
  3. AT+CFUN=0
  4. AT+CFUN=1
  5. Wait network registered
  6. reproduce issue
  7. once reproduced issue and then STOP collect log
