Hi!
I am asked to verify that the VoLTE setup provided by our partner vodafone works as expected. For that I would like to use ab BG95-M3 EVB kit I already have.
According to documentation by VF, these VoLTE settings should be integrated in to the firmware:
Vodafone IoT 90128 Variant Settings
Is that the case, or is a modified firmware available? In any case, please provide current firmware for the device.
Kind regards,
André
Hi!
No one can help, not even support?
Please share you BG95 firmware version via AT+QGMR command, some versions are not support VOLTE feature.
Hi!
Thanks for answering. I’m using an EVB kit, it has audio breakout . Please provide a current firmware which does. Vodafone also provides the IMS settings in form of an excel document. How can I convert these so that I can upload these settings to the modem?
I can provide the settings file, but currently I am not allowed to upload these to this thread.
Please notice that this is a PoC for a bigger home emergency project.
I’ve rad about the AT*+*QNVFW command. Please provide documentation so that I can configure IMS APN and all VoLTE settings.
Hi
Please take reference with attach Application Note.
Quectel_BG95&BG77&BG600L_Series_Voice_Application_Note_V1.0.pdf (602.4 KB)
