According to the BG95 Hardware datasheet the BG95-M3 support an eSIM.
Where can I find more information about eSIM support on the BG95-M3 ?
For instance:
Does it support M2M solution eSIMs, Consumer solution eSIMs or both ?
How do I install new profiles with a LPA on an eSIM if Consumer solution eSIM is supported ?
Hi Miche
Only support M2M solution eSIM.
hi, do i need to set up anything in particular for the modem to be able to handle M2M esims? in a more concrete way, do i need to modify anything with the bip/auth command?
Generally there is no need to do anything with module.
TomK
September 24, 2023, 8:02pm
5
Does BG95-M3 support the AT+QESIM commands? Is there future support planned?
Hi @TomK
Custom firmware support eSIM. for general firmwares are not support this feature.
TomK
October 9, 2023, 5:53pm
7
Is it possible to email me firmware that supports eSIM?
Hi @TomK
I’m sorry we can’t, for this firmware need place an order with local Quectel Seller.
TomK
November 2, 2023, 2:01pm
9
Hey, can you advice which devices support AT+QESIM commands on the standard firmware?
TomK:
AT+QESIM
Hi @TomK
Sorry for the late response.
Would you mind share your product region ? there are different model on different region.
TomK
November 21, 2023, 3:08pm
11
Hey, region is USA and maybe EU.
EC200-U should be support eSIM
