BG95-M2 latest FW?
Hi, I just got an EVK and a BG95-M2 board for it, however I immediately discovered lots of problems with the FW, it drops characters when doing TCP socket transfers (both directions) and it loses internet connectivity if left on for 24 hours. The main COM port seems to be dead as well (I’m using the USB-port).
Also during startup, it seems it is issuing a bunch of commands for itself, which are visible on the USB port, I’m not really sure if this is desirable? Shouldn’t the MCU do all setup things?
In either case, I want to verify release notes for the version I have now and subsequent versions and try with the latest firmware.
at+qgmr shows:
BG95M2LAR02A04_01.010.01.010
Thanks!
Hi @brodertuck
Please check your email.
Hi, I have the module BG95-M2 with the following firmware BG95M2LAR02A05_01.002.01.002
Can you send me the latest stable firmware version of the firmware with the update information?
Region: LAR
Network: LTE Cat‑M
Hi @Humberto
Please find the FW in your email.
