Hello Everyone,
I am trying to update my BG95-M2 firmware locally.
I got firmwarr package from quectel.
I am trying to update firmware using AT+QFOTADL=1
but i always get error +CME ERROR: 505,
Can you tell me where should i upload my using AT+QFUL.
My file system looks like this on EFS Explorer.
and the firmware packges from quectel has this all files. which file should i upload ?
FILE:\dam\recover\firehose\partition_complete_p2K_b128K.mbn:B549726EF5B33EA4CE347D13D5790D28
FILE:\dam\recover\firehose\patch_p2K_b128K.xml:87CA795748A3D174BC89E7B5F0DC9BCF
FILE:\dam\recover\firehose\prog_firehose_nand_mdm9x05.elf:8C0DA9BAF409DC82E1FB561F6147F45C
FILE:\dam\recover\firehose\rawprogram_nand_p2K_b128K_dam_recover.xml:2704236CB4B9936DF3749ADF7139C350
FILE:\dam\update\firehose\partition_complete_p2K_b128K.mbn:B549726EF5B33EA4CE347D13D5790D28
FILE:\dam\update\firehose\patch_p2K_b128K.xml:87CA795748A3D174BC89E7B5F0DC9BCF
FILE:\dam\update\firehose\prog_firehose_nand_mdm9x05.elf:8C0DA9BAF409DC82E1FB561F6147F45C
FILE:\dam\update\firehose\rawprogram_nand_p2K_b128K_dam.xml:B1539D8325BDEEE4451776B5CE1C2D51
FILE:\mbn\common\ROW\Commercial\mcfg_sw.mbn:3C5222E2EDB54CD13F7E4BFDCDE913BF
FILE:\mbn\EU\DT\DT\mcfg_sw.mbn:D7C6C90BB055744FDB8B418E6780BF6F
FILE:\mbn\EU\Vodafone\vodafone\mcfg_sw.mbn:E0CD3CAA626F7DDE3CD3F27DED445885
FILE:\mbn\NA\ATT\FirstNet\mcfg_sw.mbn:59C65BE2C7B4781D085D4642955BDD8C
FILE:\mbn\NA\ATT\Non_VoLTE\mcfg_sw.mbn:70D571959BA684D930F1823662880995
FILE:\mbn\NA\Rogers\rogers\mcfg_sw.mbn:CDED9D6A102BCE4708A35AE3B8A9CBE1
FILE:\mbn\NA\Telus\telus_consumer\mcfg_sw.mbn:F3261F3B21EF899A73D24BC1451BF9F7
FILE:\mbn\NA\Telus\telus_jasper\mcfg_sw.mbn:F62D9D5EA40B93AD32DBCE4A451CF096
FILE:\mbn\NA\TMO\Commercial\mcfg_sw.mbn:BCE773A865092A40B518E0FEABD7B81B
FILE:\mbn\NA\Verizon\IMSless\mcfg_sw.mbn:91672DBA271B9EDBA9A45C06882C8280
FILE:\qsr4\msg_hash_5631659e-6678-4897-8951-df9c18b0a2ce.qsr4:342D19D9AFACFAA32B9D74B14D32747E
FILE:\qsr4\msg_hash_fb8d9fa0-10e4-1888-c465-6307f048667b.qsr4:9571A1833FEF3E0E936290380F190BF2
FILE:\update\apps.mbn:F78BFFC904AC00A151D2570B9BDDFD2F
FILE:\update\cmnlib.mbn:F4A4CDD87048BF0E229150B291D8DD9C
FILE:\update\devcfg.mbn:E84495ADA35D4C2DEDAEDCC084DA88D7
FILE:\update\firehose\partition.mbn:18B2E382E60577C45B5FFF124F75D320
FILE:\update\firehose\partition_nand.xml:551889BACA34550D6AF18902DCEB1262
FILE:\update\firehose\patch_p2K_b128K.xml:87CA795748A3D174BC89E7B5F0DC9BCF
FILE:\update\firehose\prog_firehose_nand_mdm9x05.elf:8C0DA9BAF409DC82E1FB561F6147F45C
FILE:\update\firehose\rawprogram_nand_p2K_b128K.xml:B8B253DF2B40FB76D37B29DEE9392DA3
FILE:\update\keymasterapp32.mbn:7A5E6383B46BC61DC89BCFCF0BDDA819
FILE:\update\multi_image.mbn:634440F669514D9F07C56349073E82E0
FILE:\update\multi_image_qti.mbn:B51E5160A934250C8B4B75416A6A77EA
FILE:\update\partition_complete_p2K_b128K.mbn:B549726EF5B33EA4CE347D13D5790D28
FILE:\update\qdsp6sw.mbn:1BE7FB63D2070B14F8079421064D35F1
FILE:\update\qdsp6sw_2.mbn:E243F6119416B8B68C7D64005A528D72
FILE:\update\qdsp6sw_paging.bin:1C1606C4E3EC099A13840F5E2CC56101
FILE:\update\rpm.mbn:DB9F796AACB019A1FF5427548BD4A76F
FILE:\update\sbl1.mbn:4E7819831833F9C1B9D0ECADDA10749A
FILE:\update\tz.mbn:AB0A76473DE1AD3CDB7B20ACF99AC4DF
I was able to update the firmware using FILE:\update\firehose\prog_firehose_nand_mdm9x05.elf using QFlash but on BG95-M2 evalution board. but my actual hardware which consists MCU and BG95 modem does not have usb so definately i can not use QFLASH. I can only update firmware via UARt.
Can anyone guide my with correcet procedure for firmware upgradtation in local way on BG95-M2
REgrads,
BD
