is it possible to exit the shutdown mode of BG95-M2 via external interrupt? Or only by powerkey or RTC?
hi,maxk
May I ask if you use the Quecpython scheme?
Yes, we are using quecpython.
Waking from shutdown by RTC works fine, but we would like to also wake from external interrupt.
hi,maxk
The module cannot be powered on via GPIO interrupt, but the GPIO interrupt can wake up the module
How does waking the module via interrupt work?
Is it only possible when in autosleep mode?
We look for a way to achieve minimal current draw with the abilty to wake up by external interrupt. The current in sleep mode (~500uA) is too high for us. We would like to achieve closer to the ~15uA of standby.
hi,maxk
yes,GPIO interrupt can only wake up modules in autosleep mode.
