Hello. From time to time I am experiencing a strange error with the BG95-M2 module. I am using it as a radio modem, controlled via UART by a host processor. After configuring the modem, i check the connection state manually once and then wait for the CEREG URC. However, sometimes the manually requested AT+CEREG sais there is no connection, but AT+QNINFO sais there is connection. There is also no URC for over 1 minute after the start. This is the log:
10013 command: AT+CGMM
10014 message: AT+CGMM
10015 message: BG95-M2
10015 message: OK
10016 command: ATE0
10017 message: ATE0
10017 message: OK
10018 command: AT+QSCLK=0
10023 message: OK
10025 command: AT+QURCCFG="urcport","uart1"
10027 message: OK
10028 command: AT+CPIN?
10030 message: +CPIN: READY
10030 message: OK
10031 command: AT+CIMI
10034 message: ---cimi---
10034 message: OK
10035 command: AT+CREG=0
10036 message: OK
10037 command: AT+CEREG=2
10039 message: OK
10040 command: AT+COPS=0
10049 message: OK
10051 command: AT+CPSMS=0
10053 message: OK
10055 command: AT+CEDRXS=0,5
10056 message: OK
10057 command: AT+CEREG?
10059 message: +CEREG: 2,2
10060 message: OK
10061 command: AT+CREG?
10063 message: +CREG: 0,2
10063 message: OK
10064 command: AT+QNWINFO
10069 message: +QNWINFO: "NBIoT","26201","LTE BAND 8",3739
10070 message: OK
LIMSRV indicates that the terminal registration network has been denied and you need to check
1)Check whether the SIM card service is normal
2)Whether you have configured APN
