I am using the GPS and MQTT API on BG95-M1 using the QuecOpen SDK. I am aware that GPS and MQTT cannot work simultaneously so I am using a timer to switch between GPS & MQTT. When I run the program the MQTT connects successfully followed by GPS after the timer expires. However, after getting the GPS when I switch back to MQTT I am unable to connect to the MQTT anymore.
What could be the cause for this?
How do I ensure that after GPS the MQTT connects successfully every time?
I have the BG96 on the Mini PCIE module.
Does the same issue apply to the BG96 e.g. does the BG96 share the RF channel between the GPS and the LTE?
Thanks Neil.
