BG95 GPS not working
I have a custom board, bg95 works fine overall, except for the GPS.
I don’t know if is the firmware, or what I am doing wrong. Even with clearance to the sky, I can’t get proper GPS data.
AT+GMR command reply:
BG95M3LAR02A03
GPS related commands have those replies:
AT+QGPSGNMEA="GGA"\r\r\n+QGPSGNMEA: $GPGGA,0,*66\r\n\r\nOK\r\n
AT+QGPSGNMEA="GSV"\r\r\nOK\r\n\r\n+QGPSLOC: , , , , , , , , , , \r\n
AT+QGPSLOC?\r\r\n+CME ERROR: 516\r\n
how can I fix it? I am in a tight deadline.
Hello @felipe
is your custom board using an active or passive GPS antenna design? And are you using the matching GPS antenna? In my general experience active antenna tend to find a lock quicker.
Anyhow, the board I am using has an active GPS antenna design. I simply attached an active antenna, turned GPS on via:
AT+QGPS=1
and since the modem had an active data connection it automatically downloaded the xtra data to help with the GPS lock.
+QGPSURC: "XTRA_DL",0
after that it took about 10 minutes for the board to get a successful GPS lock and valid data.
BTW: my BG95M3 uses the following firmware (retrieved with AT+QGMR):
`BG95M3LAR02A03_01.014.01.014
Felix
Thanks for the reply Felix.
We are using a passive antenna.
Is it possible that it could be the module firmware? Is it possile to update it?
Hello @felipe
unfortunately I don’t know if the issue you are facing is firmware related.
Yes, the firmware can be updated. I suggest you ask in this thread for the latest firmware.
Felix
Did you check your main antenna and GNSS antenna are installed correctly?
Hello Mikey.
Both are connected.
The GNSS antenna is a Chip antenna.
DO i need to be registered to the network to get a fix?
