Using a BG95
BG95M3LAR02A03
BG95M3LAR02A03_A0.301.A0.301
While uploading files via ftps from COM source to a server :
I find 2 issues:
- Flow control set to 2,2.
- AT+IFC?
- Reply:
- +IFC: 2,2<\r>
- With upload chunks of 3800 bytes it uploads fine.
- With upload chunks of some size > this ( 4096 normally fails):
- It may upload a small number of chunks then lock up requiring reset / reboot.
- It may raise CTS line then never lower CTS line.
- With a previous firmware version in a different module, 4096 was safe, anything larger failed by dropping upload data. That was with no flow control.
I see no documentation as to allowable buffer size. Is there a published or limit that can be queried?
It also seems that the flow control in this is NOT functional for ftps.
Can any of this be verified??
