we periodicaly check registration states via +QCSQ, +CEREG, +QENG
sometimes we get conflicting states:
AT+QCSQ
+QCSQ: “NBIoT”,-75,-94,85,-17
AT+CREG?;+CGREG?;+CEREG?
+CREG: 1,1
+CGREG: 2,4
+CEREG: 4,1,“4AAB”,“31FBD5”,9,
AT+QENG=“servingcell”
+QENG: “servingcell”,“SEARCH”
all commands were executed within 200ms
question: what data to trust?
It indicates that the module has successfully registered NBIOT, and you can perform AT+CGPADDR query to see if the IP address can be successfully obtained
Part 2.
Now about param SINR at +QCSQ and +QENG.
Look at documentation about SINR
SINR Integer type. A converted value of SINR. The actual SINR = (1/5) × - 20.
Range: 0–250 (that is, the actual SINR ranges between -20 dB and 30 dB).
AT+QCSQ
+QCSQ: “NBIoT”,-72,-84,129,-11
+CREG: 1,1
+CGREG: 2,4
+QENG: “servingcell”,“CONNECT”,“NBIoT”,“FDD”,250,01,31FBD5,130,1711,3,0,0,4AAB,-85,-11,-73,12,
AT+QENG=“servingcell” returns a logarithmic value of 12 for SINR
AT+QCAINFO returns a logarithmic value of 10 for primary carrier SINR
AT+QCSQ returns a logarithmic value of 120 for SINR
I agree that with the last two there might be a slight fluctuation. Although, if I query AT+QENG again immediately after, I get a value of 10 again. SINR values never vary that much in my case.
@ herbert.pan-Q Maybe something has been miscoded in the firmware?
Also be aware that it’s not
(logarithmic sinr/5) -20=SINR in dB
but it should be
(logarithmic sinr/5 * 10) -20=SINR in dB
or in other words
(logarithmic sinr * 0,2 * 10) -20=SINR in dB
