BG95: AT command to reset non-volatile settings to default?
Hi.
I have one UG95 module and one UG95-M3 module that stopped working while debugging. Commands are transmitted between the CPU and the module, but there is no GSM transmission/receiveing.
Is there a command to reset the module’s non-volatile settings to a default state?
Thanks.
You can backup those settings and when you need to reset module, you can restore it to the stage after backup.
