BG77xA-GL EMUX/ModemManager Integration
Hello All,
One of my projects requires BG770A-GL EMUX integration with systemd ModemManager. I have obtained the BG770A-GL EMUX Linux drivers and successfully compiled them for my ARM-based Embedded Linux System.
After running the EMUX utility, virtual ports (/dev/ttyMUX[0-3]) are created, allowing communication with the BG770A-GL module via AT commands.
root@localhost:~# ./mux /dev/ttyUSB0 /dev/ttyMUX 115200
Connected to serial device: /dev/ttyUSB0
Chosen baudrate: 115200
Created virtual port: /dev/ttyMUX0
Created virtual port: /dev/ttyMUX1
Created virtual port: /dev/ttyMUX2
Created virtual port: /dev/ttyMUX3
root@localhost:~# ls -l /dev/ttyMUX*
lrwxrwxrwx 1 root root 10 May  2 11:43 /dev/ttyMUX0 -> /dev/pts/2
lrwxrwxrwx 1 root root 10 May  2 11:43 /dev/ttyMUX1 -> /dev/pts/3
lrwxrwxrwx 1 root root 10 May  2 11:43 /dev/ttyMUX2 -> /dev/pts/4
lrwxrwxrwx 1 root root 10 May  2 11:43 /dev/ttyMUX3 -> /dev/pts/5
root@localhost:~#
However, ModemManager encounters difficulty communicating through /dev/pts/x devices, as it relies on udev rules which do not recognize these devices.
Could anyone provide suggestions on how to integrate ttyMUX with ModemManager effectively?
Any assistance would be greatly appreciated.
Cheers,
Or if any plans to add support for EMUX in the n_gsm kernel driver? That will help us and everyone.
ModemManager do not support the EMUX virtual port.
You can use the usb port. And add the udev rules.
@Bean.Wang-Q
Thanks for your feedback.
Yes, I’m aware of that and as a alternative solution it is best if Quectel can add support for EMUX in the n_gsm kernel driver, that will solve many problems. Just like CMUX CMUX/n_gsm
@Bean.Wang-Q
Any thoughts on getting Quectel’s EMUX driver added in the n_gsm kernel driver?
But mux seems not a Linux kernel driver.
@Bean.Wang-Q
CMUX is in n_gsm kernel driver so similar stack but of EMUX.
