We are in the process of testing CAT M1 communication using the BG770A-GL module. We have successfully registered the service number with SK Telecom and are on “SRV” status. However, the status changes to “LIMITED” within a few seconds.
Below are some of the logs for your reference:
[2023-10-10_17:27:43:357]AT+CGDCONT=1,"IPV4V6","lte.sktelecom.com"
[2023-10-10_17:27:43:357]OK
[2023-10-10_17:27:45:287]
[2023-10-10_17:27:45:287]+QCOTA: 0
[2023-10-10_17:27:46:704]AT+QCDS?
[2023-10-10_17:27:46:704]+QCDS: "SRV","CAT-M",45005,2500,154420F,R13,3,154,18470,-102,-109,-7,3,0,0,0,0
[2023-10-10_17:27:46:704]OK
[2023-10-10_17:28:19:547]AT+CNUM
[2023-10-10_17:28:19:547]+CNUM: ,"01232982269",129
[2023-10-10_17:28:19:547]OK
[2023-10-10_17:28:33:356]AT+QICSGP=1,3,"lte.sktelecom.com","","",0
[2023-10-10_17:28:33:764]OK
[2023-10-10_17:28:35:381]AT+QIACT=1
[2023-10-10_17:28:35:381]ERROR
[2023-10-10_17:28:41:031]AT+QCDS?
[2023-10-10_17:28:41:031]+QCDS: "LIMITED","CAT-M",45012,2500,154420F,R13,2,154,18470,-90,-107,-3,3,0,0,0,0
[2023-10-10_17:28:41:031]OK
[2023-10-10_17:28:41:031] AT+QCDS?
[2023-10-10_17:28:41:031] +QCDS: "LIMITED","CAT-M",45012,2500,154420F,R13,2,154,18470,-90,-107,-3,3,0,0,0,0
[2023-10-10_17:28:41:031] OK
When running at+qcnc?, the output is as follows:
[2023-10-10_17:47:13:698] at+qcnc?
[2023-10-10_17:47:13:698] +QCNC: 0,17,0,,0
[2023-10-10_17:47:13:698] OK
Upon investigation, this appears to be a PLMN failure, and I would like to know how to solve this problem.
Additionally, I have a question regarding the at+cgdcont command. During the LTE activation with SK Telecom, the document submitted had PDP CIL, APN Default Context Id, and APN Context ID set to 27, 10, and 35 respectively. Should I use these Context IDs when executing the at+cgdcont command?
Regards.
