The documentation for BG770A-GL states the following for VBAT_RF voltage:
When the module starts up normally, to ensure full function mode, the minimum power supply voltage should be higher than 3.1 V.
In our current BC660K-GL design we use 3V rail and some of the components cannot work with voltage higher than this. What exactly can/will happen if we use 3V only? Will the performance decrease?
When doing some simple tests using TE-A (disconnecting from EVAL board and feeding voltage directly to the pin header on the small board) I was able to go down to 2.2V and the module was still able to connect to the network.
Are you able to specify exactly which component (part number) has 3.1V requirement so we check its documentation or manufacturer support?
As an alternative we might use BG950A-GL, but the module is bigger and we’d have to completely regesign the board and enclosure. Transition to BG770A-GL would be much easier for us.
Thank you.
