I am experimenting with NB-IoT / LTE-M using the Mikrotik KNOT, which has a BG77 onboard.
SIM card is from Norwegian operator Telenor.
Using AT+QCFG=“iotopmode”,2,1 (both NB-IOT and LTE-M) the connection establishes fine, however when I try to force it to NB-IoT using AT+QCFG=“iotopmode”,1,1 the PPP-interface acquires IP address, gateway and DNS, but it won’t let traffic through to the internet.
When the connection is running using AT+QCFG=“iotopmode”,2,1, I can see on the RouterOS INFO page that access technology from time to time changes back and forth between “LTE Cat-M1” and “EC-GSM-IoT” without me changing anything.
I want to lock it on NB-IoT in order to achieve better receive sensitivity. But how?
Throughput is no issue here, I’l only transmit av few bytes every now and then.
There are a lot of differnet names and acronyms here…is it possible that “EC-GSM-IoT” is 2G/GPRS-based IoT and not what I’m looking for?
And how can I succeed in doing what I want?
