BG77 no service and +CSQ: 99,99
Hello
Im using BG77
This is the list of command and the response of the module:
ATI
BG77
Revision: BG77LAR02A04
AT+CSQ
+CSQ: 99,99
AT+CGDCONT?
+CGDCONT: 1,“IPV4V7”,“”,“”,0,0,0
AT+QNWINFO
+QNWINFO: No Service
Check that your antenna is properly installed please.
pls run
AT+QENG=“servingcell”
ATI
BG77
Revision: BG77LAR01A04
+QENG: “servingcell”,“SEARCH”
AT+CSQ
+CSQ: 99,99
Maybe the search time of BG77 is not long enough, you need to give a longer time and try again
Thanks for the reply.
I have been trying to fix the connection problem for several days without success.
I am using a local network SIM card and also a st4sim esim chip.
I am currently in Georgia. Could the problem be in the local network?
Also, is it necessary to register an APN in advance?
Can you provide relevant AT logs?
