BG77 LTEM - HTTP DNS error (CME ERROR 714) after few hours
We are facing issues related to HTTP DNS ERROR (+CME ERROR 714) with using BG77 module. It appears only few hours after boot.
Most of the time we are asking GNSS NMEA frames, but every minute we power off the GPS, do a HTTPS POST REQUEST to send GNSS data, then we power-on the GPS again and go further with NMEA messages.
This works fine, however few hours after boot every QHTTPPOST command gets a “+CME ERROR 714” (corresponding to a HTTP DNS error). Nothing is received by our server, and we never get back to the normal behaviour with HTTP 200 return code. It’s only resolved by a battery power-off/power-on of our device.
AT commands Init sequence:
RDY
APP RDY
ATE1
AT+QCCID
+QCCID: 89320420000002505905
AT+QGPSXTRA?
+QGPSXTRA: 1
AT+QCFG=“iotopmode”,0
AT+QCFG=“nwscanseq”,02
AT+CREG=1
AT+QICSGP=1,1,“bicsapn”,“”,“”,0
AT+QHTTPCFG=“sslctxid”,1
AT+QSSLCFG=“sslversion”,1,3
AT+QSSLCFG=“ciphersuite”,1,0xFFFF
AT+QSSLCFG=“seclevel”,1,0
AT+QHTTPCFG=“requestheader”,1
AT+QHTTPURL=21,20
CONNECT
AT+QGPSCFG=“priority”,1
AT+COPS?
+COPS: 1
AT+COPS=4,0,“Orange F”,8
AT+CEDRXS=2,5,“0100”
AT+QGPSCFG=“nmeasrc”,1
AT+QGPS=1
AT+QGPSCFG=“priority”,0
GNSS usual behaviour every 3 seconds:
AT+QGPSGNMEA=“GGA”
+QGPSGNMEA: $GPGGA,182259.00,— XXX ----1,06,0.9,57.1,M,47.6,M,56
AT+QGPSGNMEA=“RMC”
+QGPSGNMEA: $GPRMC,182259.00,— XXX —,E,0.0,220721,2.0,W,A,V
76
Every minute for LTEM HTTPS POST request:
AT+QGPSEND
AT+CREG?
+CREG: 1,5
AT+QCSQ
+QCSQ: “eMTC”,-71,-97,110,-13
AT+QIACT=1
AT+QIACT?
+QIACT: 1,1,1,“100.65.75.46”
AT+QIDNSCFG=1,“8.8.8.8”,“8.8.4.4”
AT+QHTTPPOST=379,20,20
CONNECT
+QHTTPPOST: 0,200,39
AT+QHTTPREAD=80
CONNECT
{“status”:“ok”,“tms”:1626978302.47648}
+QHTTPREAD: 0
AT+QIDEACT=1
AT+QGPS=1
When the issue appears during sending request sequence:
AT+QGPSEND
AT+CREG?
+CREG: 1,5
AT+QCSQ
+QCSQ: “eMTC”,-72,-96,127,-14
AT+QIACT=1
AT+QIACT?
+CME ERROR: 714
AT+QIDEACT=1
AT+QGPS=1
BG77 firmware version : BG77LAR02A04_01.002.01.002
Thanks for your help
based on your AT , you have use one roaming sim card , with roaming sim card , the BG95 will search network every 2 mins , i guess the root cause come from the procedure of network search ,
for the detail analysis , we need qXDM log to do more action .
pls try one local sim card first , If the problem persists,pls rech to support@quectel.com
Fixed with updating BG77 firmware to BG77LAR02A04_01.002.01.005 release
I’m having a similar problem with a BG95-M3, it works well a few times, we also change periodically to GPS mode and back (1 minute in GPS mode, 2 minutes in WAN mode), and after a few minutes, we start having error 714 on QHTTPPOST. The firmware version is the following - bg95m3lar02a03_01.011.01.011
Should I update the firmware to a more recent version? Is there any other suggestion?
Best regards
Fernando
