We are using a BG77 but we have many issues :
GNSS stuck in a position (always sending the same position)
Random DNSS issue
Difficulty to go in PSM / eDRX mode.
The FW version is : BG77LAR02A04_01.002.01.002
Could you confirm if w are using the last one or not. If not, could you provide the last version of the firmware for BG77?
Thank you
Best regards
no, I wil send the latest firmware to you via email.
Hello Isaac,
We are facing issues with the firmware image download, receiving a « 708 » error.
Regarding the DFOTA documentation, it appears to be a « Downloaded file is too large » issue.
How can the image size be too large ? I mean, as this a BG77 firmware image, I believe it’s designed to fit into the BG77 flash memory.
Is there a point I missed ?
Here is the AT command I used and the following responses.
AT+QFOTADL=“https://antoine-poirier.com/downloads/BG77LAR02A04_01.005.01.005.zip”
+QIND: “FOTA”,“HTTPSTART”
+QIND: “FOTA”,“HTTPEND”,708
Thanks for your help
rbence
September 6, 2021, 9:34am
#4
Hello @quantum ,
Have you managed to solve this issue?
Best regards,
Bence
Hi Isaac,
I have some errors with the location on bg77 and I am looking for the latest firmware in binary format (.bin).
Where can it be found?
Kind regards,
Rafaella
Hi Isaac,
Is there a newer version from BG77LAR02A04_01.005.01.005. Since I have updated to this the NTP server doesn’t work reliably…
Please let me know if there is a known error regarding this update…
Kind regards,
Rafaella
Ok, I will send the latest firmware to you.
rob
November 2, 2021, 4:32pm
#9
Hi Isaac, could you please share the firmware and the notes of the changes in all versions with me as well? Why isn’t this publicly available by the way?
thanks!
Rob
The company stipulates that attachments are not disclosed on the forum.
Hello @quantum , I am facing the same downloaded file too large issue on BG77 (FW ver : BG77LAR02A04_01.001.01.001) . Did you manage to solve it ?
Thanks.
So the solution is that you need to send your current firmware version (of modem) and the target firmware version (to which you want to update) to support@quectel.com and ask them for a differential packet. Then use that new packet for the update.
