BG77 DFOTA via COM: and need delta FW pkg
We plan to do BG77 FW upgrade by our FW via UART port.
  1. Need BG77 delta FW pkg for DFOTA via UART1 port.
The FW version now in module: BG77LAR02A04_01.005.01.005
TAhe target version to upgrade: BG77LAR02A04_01.201.01.201
  1. In BG77 DFOTA application note don’t have example, please advise the correct SOP.
  2. Please help to verify the below sequence is correct:
    a. AT+QFOTADL=“COM:”,xxx,yy (xxx bytes, time out yy secs)
    b. When CONNECT apprears, start to send delta pkg bin (xxx bytes)
    c. Until receive the below msg from UART:
    +QFOTADL: xxx,
    d. then?
  3. AT+QFOTADL=12 have different response in different FW ver for checking available flash capacity,
    a. BG77LAR02A04_01.005.01.005, returns +CME ERROR: 590
    b. BG77LAR02A04_01.201.01.201, returns +QFOTADL: 12,6946816
Thank you.
+QFOTADL: xxx,
d. AT+QFOTADL=1 //start upgrade
