Hi there,
this is the firmware version of our BG77 EVB:
BG77LAR02A02_01.003.01.003
Unfortunately we get an error on each CoAP AT command. Is there a special setting or an update of the firmware required?
Thanks a lot!
Best regards
Hi there,
Thanks a lot!
Best regards
please update the current firmware,BG77LAR02A02 don’t support CoAP
BG77LAR02A04_01.008.01.008.zip
I recommend that you first test the HTTP server by HTTP application note in order to verify server
I am having a similar problem that my BG77 does not support CoAP.
ATI
BG77
Revision: BG77LAR02A04
The firmware link above no longer works.
Can you send me a link to the latest firmware please?
Best regards,
Daithi
Thanks for the fast response!
