I have been trying to set the edrx window and although it says ok (no error) it doesn’t enable it.
AT+QPTWEDRXS?
AT+QPTWEDRXS?
hi,rneofy:
The parameters <Requested_paging_time_window><Requested_eDRX_value> you configure are that the terminal requests to the network, but eDRX is ultimately determined by the network;
+QPTWEDRXS:0 //Disable the use of requested paging time window and eDRX
The above result indicates that the current network does not support the eDRX function.
