Could you provide prequisities for the audio loop to turn on because it seizes to work. It should be very straightforward, so what am I missing… The loop has worked before with the same device, so this might be a powering issue…
RDY APP RDY ATE0
OK AT+QAUDLOOP=1
Hi @the_kaitsu
BG77 do not support this command.
Hi @Linkin-Q
Does BG95-M2 support this command? I am getting an error too:
[2026-03-03_15:32:37:639]AT+QAUDLOOP [2026-03-03_15:32:37:639]ERROR
I have the latest firmware: BG95M2LAR02A04_A0.304.A0.304
Hi @oezgen
BG95M2 not support this command.
