in the AT Commands Manual 2.0 of the BG600L-M3 I found the chapter ‘1.8 Turn off Procedure’.
Means this, without following this procedure and a sudden power-loss the module does not function properly any more ?
Regards
wirelessguy
Regards
wirelessguy
This is a recommended power-off method to avoid data loss. Other power-off methods are also acceptable, but may cause loss of your service data. However, the module can be used normally after being powered on again.
Thank you for the fast repsonse ![]()
