Hi all,
Does anybody know if the SSL client of the BG-96 supports session caching and resumption, when that feature is supported by the server it connects to?
I am using firmware version A08 by the way.
Thank you,
Stathis
Hi all,
Thank you,
Stathis
BG96 supports resumption, but there’s no command to configure it. Module enable it by default. In one powering up, if module connect to one SSL server the 2nd time, it will use resumption.
Best Regards,
Hi Willie,
Thank you for your reply.
We found out in the meantime that SSL session resumption works OK in the latest BG-96 firmware BG96MAR02A08M1G_01.013.01.013. However, it was not working in the previous versions.
Thank you,
Stathis
