I am working on Quectel ec20 module and beaglebone black AM335x processor and need them to connect through USB communication on Windows host. The bbb has TI-RTOS SDK in it with CODE COMPOSER STUDIO IDE. so I dont know how to write C code to send and receive data using AT commands. Do help me out.
I am beginner in C and baeglebone
Have you installed the driver?
Can you see the virtual serial port in the device manager?
Be familiar with the AT commands purpose first.
I don’t know what the CODE COMPOSER STUDIO IDE is like, but I think it will provide you C API to access the serial port.
You need to realize that every AT command has to end with an “\r\n”.
Basically the baeglebone should be connected with quectel module through USB, and i need a C SCRIPT( C program with AT Commands) to send and receive data which is compatible with SDK TI-RTOS format.
c codes are available in net but having doubt whether it will run or not code composer studio.
I am not using linux based usb driver. i have windows based USB driver
instead of using q-com tool from quectel. i need in a c program
