I am getting an error when issuing a AT+QIACT=1 command.
Is there a firmware upgrade for this module?
My firmware is currently.
BG96MAR02A07M1G_01.017.01.017
You can use AT+QIACT, right? Check whether the scene is activated. If the scene is activated, an error occurs when you run AT+QIACT=1。
If you need the new firmware, you can send your email to me, and I will send it to you by email.
Thankyou,
my email is: richardmarmstrong@outlook.com
The new firmware has been sent to you by email, please note to check.
How can I tell if the scene is activated?
You can use "AT+QIACT? "Query the activation status. I sent you a guide.
When I try the command I get no activation status:
AT+QIACT?
AT+QIACT=1
ERROR
AT+QICSGP=1
+QICSGP: 1,“telstra.internet”,“”,“”,1
Your steps are wrong, there is a correct setup process in the guidance document, you can look at it.
at
AT+CPIN?
+CPIN: READY
AT+CGREG?
+CGREG: 0,4
AT+CEREG?
+CEREG: 0,3
AT+QICSGP=1
AT+CGDCONT?
+CGDCONT: 1,“IP”,“telstra.internet”,“0.0.0.0”,0,0,0,0
AT+QIACT?
AT+QIACT=1
ERROR
AT+CREG?
+CREG: 0,2
AT+CEREG?
+CEREG: 0,2
I’ve also done a factory reset.
At&F0
AT&W0
yes, that’s my problem.
I thought the problem may be because the QIACT command didn’t work.
AT+QIACT?
AT+QIACT=1
ERROR
This is a network problem, not an AT+QIACT command problem, you need to check whether your network and sim work properly.
Can you execute the following command to see the return value
AT+COPS=?
AT+QNWINFO
AI+CPIN?
Here are the results:
AT+COPS=? +COPS: (0,“Optus AU”,“Optus”,“50502”,9),(0,“Telstra Mobile”,“Telstra”,“50501”,9),(0,“vodafone AU”,“voda AU”,“50503”,9),(0,1,2,3,4),(0,1,2)
AT+QNWINFO +QNWINFO: No Service
AT+CPIN? +CME ERROR: 13
After a soft restart I get
AT+QNWINFO +QNWINFO: “CAT-NB1”,“50501”,“LTE BAND 28”,9502
AT+CPIN? +CPIN: READY
Execute the following commands to try whether you can register on the network. In addition, according to the operation instructions you show, your sim may not be recognized due to poor contact, please pay attention to check.
AT+CFUN=0
AT+QCFG=“NWSCANSEQ”,030201
AT+QCFG=“NWSCANMODE”,0
AT+QCFG="IOTOPMODE"2
AT+CFUN=1
AT+QNWINFO
AT+CREG?
+CREG: 0,2
Still doesn’t connect. I’ve tried 3 SIM cards and I have the same result will all of them.
Have you checked with your carrier to see if your SIM card supports NB networks?
