Hello
I use BC95-G Modem and I am trying to enable PSM mode ,
I measure only the power of the module directly at power pin.
The modem register on the network, I get the TAU and Active timer registers from the network (from CEREG Command)
also I get the NPSMR response that the modem is in PSM mode but the current consumption is stack on 1.8mA.
The only way to see lower consumption (about a couple of uAmps ) is to disable the radio with the cmd AT+CFUN=0
I post AT Command Log
Boot: Unsigned
Security B… Verified
Protocol A… Verified
Apps A… VerifiedREBOOT_CAUSE_SECURITY_PMU_POWER_ON_RESET
Neul
AT
AT+NCONFIG=AUTOCONNECT,FALSE
OKREBOOTING
J
Boot: Unsigned
Apps A… VerifiedREBOOT_CAUSE_APPLICATION_AT
Neul
OKAT+CEDRXS=0,5
OKAT+NPSMR=1
OKAT+CEREG=4
OKAT+CFUN=1
+CEREG:0,0000,00000000,9,+NUSIM: PIN REQUIRED
ERROR
+NPSMR:1 <---- I get a response that I am in PSM mode without network registration ???
AT+NPIN=0,“1111”
OK+NPIN: OK
AT+CGATT=1
OK+CEREG:2,0000,00000000,9,
+NPSMR:0
+CEREG:1,1F40,00036A49,9,00010000,00110001
+NPSMR:1 <— informs me that I am in PSM mode but the consumption is at 1.8mA!
AT+CEREG?
+CEREG:4,1,1F40,00036A49,9,00010000,00110001 <---- I get the Active and Tau timers from networkOK
AT+CPSMS?
+CPSMS:1,00110000,00000101 <— PSM configuration
ATI
BC95-G
Revision:BC95GJBR01A07
