BC95-G Network Registration Status error
Hi.
The ATI response message for the NB-IoT in use is as follows,
BC95-G
Revision:BC95GJBR02A03_LGU
We are testing the function of checking the network connection status 12 seconds after hardware reset.
Logs in Test Progress
[Normal]
modemTx->AT+CEREG?
+CEREG:0,2
modemTx->AT+CEREG?
+CEREG:0,1
[Abnormal]
modemTx->AT+CEREG?
+CEREG:0,2
modemTx->AT+CEREG?
+CEREG:0,2
modemTx->AT+CEREG?
+CEREG:0,2
modemTx->AT+CEREG?
+CEREG:0,2
If it is normal, wait about 12 seconds, and within 10 seconds, the network is confirmed to be normal
When abnormal, waiting 12 seconds and reading the status value for 3 minutes did not change the network registration status.
This situation occurs frequently, so I would like to ask you how to normalize communication quickly in case of abnormality.
I want to know, is the terminal registration more likely to succeed, or more likely to fail?
Through the log analysis you provided, the registration may fail due to the reasons of radio signals. If permitted, I need you to provide debug log for detailed analysis
Quectel_UEMonitor操作指导与参考(CN&EN)_BC28&BC95&BC68&BC35G&BC95G.pdf (1.3 MB)
I tried it while looking at the manual
The Message.xml file is not visible.
Where can I get it??
BC95GJBR02A03_LGU.zip (2.1 MB)
thank you~
We got debug logs thanks to you.
However, I can’t upload the file because I’m a new user, so I’m sharing it through Google Drive link.
https://drive.google.com/file/d/1sDwB4lm9gdi9-_8GqBtACFgmHWu3Ql7T/view?usp=drive_link
pls send to my email, herbert.pan@quectel.com
I’ve sent you an e-mail.
thank you~
Through the analysis of the Log provided by you, the terminal registration network and sending and receiving data are normal during this period. Please continue to monitor abnormal logs
