Hello everyone,
I hope this message finds you well. I’m currently facing a puzzling issue with my NB-IoT project and I’m hoping someone here could provide some guidance. I’ve been working with a Dragino shield for NB-IoT, and I derived my code from the example available at this link: NB-IoT/NB-IoT Shield/examples/nbiot_testing1/nbiot_testing.ino at master · dragino/NB-IoT · GitHub
Initially, I was able to configure the code in a way that I could retrieve data from the serial port using commands like “+CSQ18” and “+CEREG:0,5”. However, after making some modifications (or perhaps mistakes), I’ve encountered an unexpected change in the serial output, which now displays “+CSQ_99” instead. My understanding of this field is limited, and I find myself quite lost at the moment.
To provide more context, I’m using an NB-IoT SIM card from the company 1nce, and my objective is to establish a connection with the “mqtt.mydevices.com” server.
I would greatly appreciate any insights you can offer regarding the potential causes of this issue and any recommendations for resolving it.
Thank you in advance for your assistance!
#include <SoftwareSerial.h>
const int timer = 15000; //timer, default: six minites;
/define Serial port*/
const byte rxpin = 10; //Software Serial port
const byte txpin = 11;
const char server = “180.101.147.115”; //CDP server of China Telecom
const int port = 5683; //server port
const char udpserver = “120.78.138.177”; // UDP server of dragino
static char retmcu[256] = {‘\0’}; //save the mcu return message for AT Command
static byte reboot = 0;
static char IMEI[16] = {‘\0’};
#define MAXLEN 256 // MAX Payload length
#define CHARLEN 32
#define BAUDRATE 9600 //define the baud is 9600bps/s
void mcu_init(); //CPU初始化
int mcu_at_nmgs(int, char *);
void send_data_udp(int, char *);
void read_downstream();
char *mcu_get_imei(char *);
SoftwareSerial bc95_serial(rxpin, txpin); // RX TX
funciton name :setup()
parameter :NONE
return value :NONE
effect :initialize Arduino’s function of setu
data :2018/4/16
void setup() { //set the data rate for the Serial port
Serial.begin(BAUDRATE); // Use Serial Port for debug(config the baud of uart is 9600bps/s)
bc95_serial.begin(BAUDRATE); //config module of bc95 baud of uart is 9600bps/s too.
mcu_init(); //module were initialized.
delay(1000); //Arduino delay 1 second
funciton name :loop()
parameter :NONE
return value :NONE
effect :NB-IoT init and send for data to platform
data :2018/4/16
void loop() {
char temp[] = “Send a UDP datagram containing length bytes of data”; //the array was defined ,the data was straged on it
Serial.println(F(“Send a message use UDP Protocol”)); //computer will printed to char string
send_data_udp(strlen(temp), temp); //send to udp server
delay(1000); //delay 1 second
Serial.println(F(“Send a message use CoAP Protocol”)); //computer will printed to char string
mcu_at_nmgs(3, “020103”); //send message to CoAP server, for testing
delay(timer); //delay(1500)
read_downstream();
delay(1000);
funciton name :bc95_serial_read()
parameter :NONE
return value :NONE
effect :data was straged in retmcu array
data :2018/4/16
void bc95_serial_read()
int i = 0;memset(retmcu, 0, sizeof(retmcu));//reference c language lib menset
//array is cleaned in here
bc95_serial.flush(); //Waits for the transmission of outgoing serial data to complete.delay(1500); //Waits for respones from server
while(bc95_serial.available() && i < sizeof(retmcu) - 1) {
retmcu[i] = bc95_serial.read();//read return’s value and strage in this array
i++;
}retmcu[i] = ‘\0’; //
Serial.println(retmcu); //for debug
funciton name :bc95_serial_clearbuf()
parameter :NONE
return value :NONE
effect :clear the buffer
data :2018/4/16
void bc95_serial_clearbuf()
bc95_serial.flush();while(bc95_serial.available()) {
bc95_serial.read();
funciton name :str2hex()
parameter :NONE
return value :NONE
effect :conver strings to ascii code
data :2018/4/16
void str2hex(char *hexstr, int hexlen, char *str, int strlen)
int i;
char tmp1[4] = {‘\0’};
for (i = 0; i < strlen - 1; i++) {
sprintf(tmp1, “%x”, str[i]);
strncat(hexstr, tmp1, hexlen);
- funciton name :mcu_at_nrb()
- parameter :NONE
- return value :NONE
- effect :Sent the AT command
- data :2018/4/16
void mcu_at_nrb()
bc95_serial_clearbuf(); //clear the buffer
Serial.println(F(“Reboot BC95”)); //
bc95_serial.println(F(“AT+NRB”)); //send AT+NRB command to NB-IoT,this command is that module will be reboot
/ - funciton name :mcu_at_ok()
- parameter :NONE
- data :2018/4/16
void mcu_at_ok()
while(1) {
bc95_serial.println(F(“AT”)); //send "AT"command to NB-IoT
bc95_serial_read(); //read the return value
if (strstr(retmcu, “OK”) != NULL) { //if return value is “OK” than program delay 1second jump out loop
delay(1000);
break;
funciton name :mcu_get_cimi
parameter :NONE
return value :NONE
effect :Sent the AT+CIMI command
data :2018/4/16
void mcu_get_cimi()
while(1) {
bc95_serial_clearbuf(); //flush bc95_serial
Serial.println(F(“AT+CIMI”)); //
bc95_serial.println(F(“AT+CIMI”)); //send AT+CIMI command to NB-IoT module
break; //jump out of loop
funciton name :mcu_get_imei
parameter :*char
return value :*char
effect :gain the IMEI code
data :2018/4/16
char *mcu_get_imei(char *imei)
int i;
char *pt; //this pointer in order to recevied the IMEI code take in imei arraybc95_serial_clearbuf(); //clear the buffer
Serial.println(F(“AT+CGSN=1”)); //
bc95_serial.println(F(“AT+CGSN=1”)); //send the "AT+CGSN=1"command,then the return value is IMEI code
bc95_serial_read(); //read return code//judge if have return value of IMEI code
if (strstr(retmcu, “+CGSN”) != NULL) { /* respones format: +CGSN:86370303110??? */
pt = strrchr(retmcu, ‘:’); //
for(i = 0; i < sizeof(IMEI); i++) {
imei[i] = pt[i+1]; //store the IMEI code to imei array.
return imei; //return the imei array
}return NULL; //or return NULL
- funciton name :mcu_at_nband()
- parameter :NONE
- effect :Arduino sent"AT +NBAND"to NB-IoT,we choose 850Mhz working frequency
- data :2018/4/16
void mcu_at_nband()
while(1) {
bc95_serial_clearbuf(); //clean the buffer to NB-IoT
Serial.println(F(“AT+NBAND?”)); //Arduino print “AT+NBAND?” char string to computer
bc95_serial.println(F(“AT+NBAND?”)); //Arduino send “AT+NBAND?“command to NB-IoT,in order to looking the module work in state
if(strstr(retmcu, “+NBAND:5”) != NULL) { //Read the retmcu array,Arduino start judge the value appear nbnber"5”
break; //if the value is number"5”,NB-IoT working frequency is 850Mhz,jump out of the loop.
} else {
Serial.println(F(“AT+NBAND=5”)); //if the return value isn’t number"5",afterward,Arduino sent "AT+NBABD=5"command to NB-Iot module.
bc95_serial.println(F(“AT+NBAND=5”)); // AT+NBABD=5 command is chose the mode that NB-IoT working frequency is 850Mhz
reboot = 1; //reboot laber bit assignment is “1”.
break; //program jumps out of the loop
/ - funciton name : mcu_at_cgdcont()
- parameter :NONE
- effect :Define a PDP Context * notice:
- data :2018/4/16
void mcu_at_cgdcont()
Serial.println(F(“AT+CGDCONT=1,IP,CTNB”));
bc95_serial.println(F(“AT+CGDCONT=1,"IP","CTNB"”));
delay(1000);
Serial.println(F(“AT+CGDCONT?”));
bc95_serial.println(F(“AT+CGDCONT?”));
bc95_serial_read();
/ - funciton name :mcu_at_nconfig()
- parameter :NONE
- effect :send AT+NCONFIG command,look for NB-IoT message of config
- data :2018/4/16
void mcu_at_nconfig()
while(1) {
Serial.println(F(“AT+NCONFIG?”)); //
bc95_serial.println(F(“AT+NCONFIG?”)); //send “AT+NCONFIG"command
bc95_serial_read(); //return the value
if(strstr(retmcu, “+NCONFIG:AUTOCONNECT,FALSE”) != NULL) { //if return value isn’t”+NCONFIG:AUTOCONNECT,FALSE",this isn’t auto look for network…
Serial.println(F(“AT+NCONFIG=AUTOCONNECT,TRUE”)); //
bc95_serial.println(F(“AT+NCONFIG=AUTOCONNECT,TRUE”)); //then send for"AT+NCONFIG=AUTOCONNECT,TRUE"command to NB-IoT
reboot = 1; //1reboot module laber is “1”
break; //break the while(1)
} else if (strstr(retmcu, “+NCONFIG:AUTOCONNECT,TRUE”) != NULL) {//
break; //
} else { //this is else if wait for appear return is ture
//Do Nothing
/ - funciton name :mcu_at_csq()
- parameter :NONE
- effect :send "AT+CSQ"command,look for singal strengh
- data :2018/4/16
void mcu_at_csq()
while(1) {
Serial.println(F(“AT+CSQ”));
bc95_serial.println(F(“AT+CSQ”));
bc95_serial_read();
if(strstr(retmcu, “+CSQ:99,99”) != NULL) { // res 99 is nosignal
continue;
} else if (strstr(retmcu, “+CSQ:”) != NULL) {
break;
} else {
// Do Nothing
/ - funciton name :mcu_at_cgatt()
- parameter :NONE
- effect :send "AT+CGATT"command,detect network if activate
- data :2018/4/16
void mcu_at_cgatt()
while(1)
bc95_serial_clearbuf(); //clear the send buffer
Serial.println(F(“AT+CGATT?”));
bc95_serial.println(F(“AT+CGATT?”)); //"AT+CGATT"command
if(strstr(retmcu, “+CGATT:1”) != NULL) { //return value 1:active,0:disavtive
break; //active break while
/ - funciton name :mcu_at_cfun()
- parameter :NONE
- effect :send "AT+CFUN"command,enable Receive and send
- data :2018/4/16
void mcu_at_cfun()
while(1) {
Serial.println(F(“AT+CFUN?”));
bc95_serial.println(F(“AT+CFUN?”)); //send “AT+CFUN"command to NB-IoT module
bc95_serial_read(); //read return value
if(strstr(retmcu, “+CFUN:1”) != NULL) { //if return value is"1”,reprense NB-IoT enable receive and send port,at the moment break the while
break;
} else { //or wait for return is"1"
//Do Nothing
/ - funciton name :mcu_at_cereg()
- parameter :NONE
- effect :send "AT+CEREG"command,look for EPS network is register state
- data :2018/4/16
void mcu_at_cereg()
while(1)
Serial.println(F(“AT+CEREG?”));
bc95_serial.println(F(“AT+CEREG?”)); //send "AT+CEREG?"command to NB-IoT
bc95_serial_read();
if(strstr(retmcu, “+CEREG:0,1”) != NULL) { // res +CEREG:n,stat , stat=2 indicate not registered
break;
if(strstr(retmcu, “+CEREG:5,1”) != NULL) {
break;
/ - funciton name :mcu_at_cscon()
- parameter :NONE
- effect :send "AT+CSCON"command
- data :2018/4/16
void mcu_at_cscon()
while(1)
Serial.println(F(“AT+CSCON?”));
bc95_serial.println(F(“AT+CSCON?”));
bc95_serial_read();
if(strstr(retmcu, “+CSCON:0,1”) != NULL) { //res +CSCON:n,mode , if mode=1 connected, 0 idle
break;
- funciton name :mcu_at_ncdp()
- parameter :NONE
- effect :send "AT+NCDP"command,config and look for CDP server
- data :2018/4/16
void mcu_at_ncdp()
while(1) {
Serial.println(F(“AT+NCDP?”));
bc95_serial.println(F(“AT+NCDP?”));
bc95_serial_read(); //query the "AT+NCDP"command,read return value
if(strstr(retmcu, server) != NULL) //return value is not NULL,break the while
break;
else {
Serial.println(F(“AT+CFUN=0”));
bc95_serial.println(F(“AT+CFUN=0”));
bc95_serial_read(); //send "AT+CFUN=0"command and read return value
if(strstr(retmcu, “OK”) != NULL) { //
char cmd[32] = {‘\0’};
snprintf(cmd, sizeof(cmd), “AT+NCDP=%s,%d”,server, port);
bc95_serial.println(cmd);
bc95_serial_read();
bc95_serial.println(F(“AT+CFUN=1”));
delay(500);
break;
/ - desc: send a message from the terminal to network via connect
- device platform server. (CDP)
- ret: return 0 if send message success
int mcu_at_nmgs(int len, char *data)
char cmd[256] = {‘\0’};
snprintf(cmd, sizeof(cmd), “AT+NMGS=%d,%s”, len, data);
Serial.println(cmd);
delay(1000); //wait 1 sencond
bc95_serial_read();
return 0;
return 1;
- desc: Queries the status of downstream messages received from
the CDP server - Res: BUFFERED=, RECENIVED=, DROPPED=
+CME ERROR:<err>
void mcu_at_nqmgr()
Serial.println(F(“AT+NQMGR”));
bc95_serial.println(F(“AT+NQMGR”));
bc95_serial_read();
the CDP server - note:
int i;
char *sp, buf[8];
mcu_at_nqmgr();
if ((strstr(retmcu, "BUFFERED=")) != NULL) {
sp = strchr(retmcu, '=');
for (i = 0; sp[i] != ',', i < 8; i++) {
buf[i] = sp[i + 1];
buf[i] = '\0';
if (atoi(buf) > 0)
mcu_at_nmgr();
- desc: Queries the status of the upstream messages
sent to the CDP server - note:
- Res: PENDING=, SENT=, ERROR=
void mcu_at_nqmgs()
Serial.println(F(“AT+NQMGS”));
bc95_serial.println(F(“AT+NQMGS”));
bc95_serial_read();
- desc: return the oldest buffered message and deletes from buffer
- note: if new message indications(AT+NNMI)are turn on then received
- messages will not be available via this command
void mcu_at_nmgr()
Serial.println(F(“AT+NMGR”));
bc95_serial.println(F(“AT+NMGR”));
bc95_serial_read();
- desc: create udp socket
- AT+NSOCR=,,[,]
- udp type:DGRAM, protocol:17, receive control default is 1 message will be receive
- note: if a socket has already created, will fail if requested a second time
void mcu_at_nsocr()
Serial.println(F(“AT+NSOCR=DGRAM,17,5999,1”));
bc95_serial.println(F(“AT+NSOCR=DGRAM,17,5999,1”));
bc95_serial_read();
desc: send data to udp server
AT+NSOST=socket,remote_addr,remote_port, length, data
socket: number return by AT+NSOCR, 0 as default
void mcu_at_nsost(int len, char *data)
int i;
char imeihex[32] = {‘\0’};
char datahex[MAXLEN] = {‘\0’};str2hex(imeihex, sizeof(imeihex), IMEI, strlen(IMEI));
str2hex(datahex, sizeof(datahex), data, len);
snprintf(retmcu, sizeof(retmcu), “AT+NSOST=0,%s,%d,%d,%s3D%s”, udpserver, port, len + strlen(IMEI) - 1, datahex, imeihex);
bc95_serial.println(retmcu);
bc95_serial_read();
- desc: read the req_length characters of data from socket
void mcu_at_nsorf()
Serial.println(F(“AT+NSORF=0,512”)); // read 512 characters form socket 0
bc95_serial.println(F(“AT+NSORF=0,512”)); // read 512 characters form socket 0
bc95_serial_read();
if(strstr(retmcu, “+NSONMI:”) != NULL) { // +NSONMI: has message
bc95_serial_read();
funciton name :mcu_at_cgpaddr()
parameter :*ip
return value :NONE
effect :send "AT+CGPADDR"command,display the PDP addr
data :2018/4/16
void mcu_at_cgpaddr()
Serial.println(F(“AT+CGPADDR”));
bc95_serial.println(F(“AT+CGPADDR”));
bc95_serial_read();
funciton name :mcu_at_nping()
parameter :*ip
return value :NONE
effect :ping
data :2018/4/16
void mcu_at_nping(char ip)
char cmd[64] = {‘\0’};
snprintf(cmd, sizeof(cmd), “AT+NPING=%s”, ip); //函数原型为int snprintf(char str, size_t size, const char format, …)
funciton name :mcu_init()
parameter :NONE
return value :NONE
effect :init the NB-IoT module
data :2018/4/16
void mcu_init()
mcu_at_nband(); //choose the NB-IoT working band
mcu_at_nconfig(); //config auto look for networkif (reboot) {
reboot = 0; //
mcu_at_nrb(); //reboot the NB-IoT module
delay(5000); //delay 5 second
}if (NULL == mcu_get_imei(IMEI))//if return value is null,Arduino Send char string to computer port
Serial.println(F(“IMEI = NULL”));
else {
Serial.print(F(“IMEI=”));
Serial.println(IMEI); //else Arduino send IMEI code to computer port
}mcu_at_ncdp(); //query IP addr
mcu_at_csq(); //query signal if strengh
mcu_at_cgatt(); //Send “AT+CGATT” command
mcu_at_cereg(); //query network register satues is success,"1"resprent success
mcu_at_cgdcont(); //quest work statues,second parameter is return statues,“1” represent is connet
mcu_at_cgpaddr();
mcu_at_nsocr(); // Greate a SOcket
- desc :
void send_data_udp(int len, char *data)
mcu_at_nsost(len, data);
- desc :
void mcu_rec_data()
mcu_at_nsorf();
