Dear All:
I have an application using the above module which is managed for a microcontroller usign AT commands, thas is, the microcontroller send/receive AT Commands to the module.
Now we want to use MQTT with the AWS platform to send/receive data. For the moment, I understand that I have to upload to the module several files (private key, certificate…) but I dont find the way to do it.
Is there any manual explaining how to do this? Any example?
This is the module revision: Quectel BC95-G, Revision: BC95GJBR01A05
Thanks in advance,
Joaquin.
hi,cerroelectronic:
Sorry, BC95G does not support MQTTS.
You can test standard MQTT in non-secure mode
