Good day! I have a question regarding the BC92 module. We want to send some data via NB-IoT via a CoAP protocol. I found an AppNote by Quectel for CoAP, that´s fine. But what I´m missing is a documentation how to connect to the NB-IoT network.
Which AT commands are necessary to do that? I see signal strength is good +CSQ 31,99. With AT+COPS I see some networks too. How do I continue? Is there an Application note or some documentation about it?
Thanks but as I said, I already read that AppNote. But I´m missing the steps before: How to connect to a NB-IoT network? How to select the appropriate network type? DO I need to setup a PDP context? and all that… I only have the full AT commands reference, but is there a document which explains which steps I have to take to configure the module from default settings to get attached to an NB-IoT network?
I am using a BC92 TEB eval board with a thingsmobile-SIMcard with Austrian telecom. It gets automatically attached to the GPRS. My final state is this one: AT+COPS=1,2,“23203”
How can I proceed?
Thanks for the advice. I selected NB-IoT band 8 but it still doesn´t work. AT+COPS doesn´t return any networks with number “9”, even if I know that this area has NB-IoT coverage. Here is the full AT command list I am sending:
ATI
Quectel_Ltd
Quectel_BC92
Revision: BC92RBR01A05
