I have been trying to test NB-IoT connection in “bad coverage” conditions. But it seems that BC68 cannot register to network even tough conditions shouldn’t be too bad for NB-IoT. I used AT+NUESTATS to measure channel conditions and here are the average results during test:
I have also logs taken by UEMonitor but I guess I can’t attach those here.
Basic procedure is that I reset the module by using AT+NRB, then I set modem functionality by AT+CFUN=1 and PLMN selection to be automated by using AT+COPS=0. I also confirm that PDP context is what I want it to be with AT+CGDCONT?. I have earlier also set correct band by using AT+NBAND, which I still confirm by using AT+NBAND?. Finally I repeat AT+CEREG? for 300s (NUESTATS is checked every 15s), and check if +CEREG: 0,1 is received.
Problem is that it is never received in these conditions. +CEREG: 0,2 is received during whole 300s period. Is there anything I could try to do to improve modules operation in bad coverage or is these conditions beyond the limit of the BC68?
Br,
Niko
