we discovered that the BC68 module (latest firmware BC68JAR01A10) doesn’t insert CoAP OPTIONS received on CoAP Response coming from the server.
We enabled insertion of received CoAP Options on CoAP Resp URC by using
AT+QCOAPCFG=“Showrspopt”,1
but the CoAP Response URC is emitted without the CoAP Options fields [,<opt_count>,<opt_name>,“opt_value>”[,…]] despite two Options are sent from the server as you can see in this capture images
related to following AT command sequence.
AT+QCOAPCREATE=56830
AT+QCOAPHEAD=5,1,4,AABBCCDD
AT+QCOAPOPTION=3,17,“42”,23,“0”,11,“/iSOS-update?sn=99990004-00-19/000-000001&model=QUECTELBC68&hw=0&fw=1.0.0&buildId=211119.1535&bs=0&fmt=bin”
AT+QCOAPSEND=0,1,88.149.255.38,5683
+QCOAPURC: “rsp”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
AT+QCOAPDATASTATUS?
+QCOAPDATASTATUS: 4
As you can see +QCOAPURC doesn’t include CoAP Options values but the server sent two Options (ETag and Block2)
Adding AT+QCOAPCFG=“Showra”,1 properly enable remote address and port insertion on CoAP Response URC as stated by AT command manual, but AT+QCOAPCFG=“Showrspopt”,1 seems ignored by BC68 module and received Options aren’t inserted into Response URC.
Is it a known issue? Workaround is available?
