According to the specifications, I should be having 3uA in PSM mode but I’m registering 300uA. I’m sure the module enters PSM since I get the notification from AT+NPSMR
I’ve tried disabling the pin using AT+CPIN=3, but still the least I can do is the 300uA. Low power consumption is critical for my application, I could use some ideas.
Thank you in advance
