HI!
I am working on a project including a BC68 NB-IoT module and I want to use it to send data over CoAP protocoll. Everithing works just fine untill I send the AT+QCOAPSEND command, I get an ‘OK’ reply, then nothing. (+QCOAPURC:… should also be received after OK) After retrying it without a reboot I keep receiving an ‘ERROR’ message. (I tested everithing on a development board, everithing worked well, so I would exclude the user errors.)
Do you have any idea hat the problem could be?
Details of the module (ATI):
BC68
Revision:BC68JAR01A09
The other question of mine is that could you provide me the latest firmware for this module?
I also wanted to use the VDD_EXT pin of the module to power other external circuits, but it proved to be a bad idea as the voltage on that pin varies betveen 3,28 and 2.7V (the nominal is 3.0V) The supply voltage is 3.3V. Why is this voltage so unstable?
Thank you for your help in advance.
Regards,
Istvan
Please provide all your execution at commands and output results
Hi!
AT+CFUN=1
AT+CGDCONT=1,“IP”,“iot.1nce.net”
AT+CGATT=1
AT+QCOAPCREATE=56830
AT+QCOAPOPTION=1,11,“/i/85361d04-25ef-b30f-14a8-XXXXXXXXXXXX”
AT+QCOAPSEND=0,2,161.35.XXX.XXX,5683
‘>’ Message to send [Ctrl+Z]
And then nothing. According to the CoAP Application note the last ‘OK’ should be followed by a +QCOAPURC: … reply.
Btw, I tested this functionality on another board (original dev board) and worked well.
AT+CEREG?
+CEREG:0,5
AT+CGPADDR
+CGPADDR:0,10.213.168.4
+CGPADDR:1
AT+CGDCONT?
+CGDCONT:0,“IPV4V6”,0,0,0
+CGDCONT:1,“IP”,“iot.1nce.net”,0,0,0
OK indicates that the command is executed successfully
rsp Indicates that the server replies to the corresponding reply data
Did the server receive the data when you executed AT+QCOAPSEND?
No, the server does not receive any data from that module. (with an other one it does, but that has other firmware wersion.)
Please provide the IMEIs of the two modules
IMEI of the malfunctioning module:
867723030034499
IMEI of the other one:
867723030470123
Well, I can’t find the corresponding version number in our database. Please run
ATI
The malfunctioning module:
BC68
The other one:
BC68
Revision:BC68JAR02A02
Is the module of BC68JAR01A09 successfully sent through COAP?
No, Its the BC68JAR02A02,
Are you just using BC68 and working on a project?
This module is currently end of life
I use this module for my thesis project. So it is not going to be in production. The 1st picture above is the PCB I made.
Is it possible that a FW update to the BC68JAR02A02 version would solve this problem?
I’ve managed to upgrade the module’s FW to BC68JAR02A02 version, as a result I managed to send successfully a message only once. Then I tried it again many times and I got the same above mentioned result.
