I’m starting with NB-IoT BC68 module, I used older sample of BC68 with origin FW 01A07, updated by QFlash_V4.16 to
BC68
Revision:BC68JAR01A10
When I’m trying to connect to the Narrow Band network I use
AT+CFUN=1 OK
AT+CGATT=1 OK
and then I see forever answer on AT+CEREG?
+CEREG:0,2
It means “Not registered, but UE is currently trying to attach or searching an operator to register to”
Network registration is not success. I’d like to see more information what happens, and expect that some interesting information should be available through Debug port. HW connected, and documentation refers to software called “UEMonitor”, but I can’t find it anywhere.
- what to use for debug port information showing?
- is there some AT command like AT&F (Set all Current Parameters to Manufacturer Defaults)?
- is some reason to use modules with newer FW version BC68JAR02A02A and if is update possible?
Sorry for much questions together, but I’m at the beginnig
Thanks,
Petr
