Hi, how can I set the RAI flag when sending a packet with AT+SEND and modem in data mode?
From BC660K-GL datasheet I can send:
AT+QISEND=< connectID>,<send_length>,< data>[,<rai_mode>]
with the RAI mode I need.
But if I use:
AT+QISEND=< connectID>,<send_length> (and data after modem enters data mode)
I can’t set the RAI mode.
I need to use data mode in my application.
Is there a workaround for setting the RAI mode?
Can I set the RAI mode before sending the packet?
You can try to execute after sending the data
AT+QPING=0,8.8.8.8,10,1,32,1
@herbert.pan-Q Thanks for the reply.
The ping operation forces an upload and download so it is overkill for releasing the RRC connection.
In BC660K-GL I can send these commands that only send a short upload to the same effect:
AT+QNBIOTRAI=1
or
AT+SEND=0,1,$,1
But what I was really looking for is a way to send the RAI mode with my upload packet and avoid another upload.
Your method is currently not supported
